Measurement Studio for VC++
right y axis
How do I plot a waveform using the right y axis as apposed to the left y axis.
(3,218 Views)
Hi Jim
Are you using Measurement Studio 6.0 with the CWGraph?  If so, you can right-click on the graph and select "Properties".  On the "Ticks" tab, select "Y-axis" from the drop down menu.  In the "Labels" section, put a check next to "Right".  That should put the axis on the right-hand side.
Hope this helps!
Russell G.
NI Applications Engineering
(3,201 Views)
