Measurement Studio for VC++
screen flicker
I am using MSVC++ to implement an image processing application. I am trying to implement the equivalent of the 'HLRing' application from the NI example directory, except I want to use the CWIMAQ and cwimaqviewer libaries. I can capture and display the images continuously, but the display flickers really badly. Does anyone know how to keep the display from flickering?
(3,841 Views)
Does the flicker occur as a result of running the software? or as a result of moving it to a new location near instruments? Power supplies are notorious for making the screen flicker.
So what I am asking is if the flicker results from the environment or from displaying the capture in software.
JLV
(3,830 Views)
It is definately from displaying the capture in the software because MAX doesn't flicker.
(3,825 Views)
mps -
There are a few known issues with flickering in the CWIMAQViewer that should be fixed soon, but there are workarounds. In your HLRing example, are you calling CWIMAQViewer.Attach every time a new image is acquired? If so, try copying the new image into a separate image (perhaps CWIMAQViewer.Image - I'm not sure how easy this is to do in C++) and only calling CWIMAQViewer.Attach once. That should clear up any flickering issues.
Let me know how this works out for you.
Greg Stoll
IMAQ R & D
Greg Stoll
LabVIEW R&D
(3,811 Views)
Thanks for your help -- it worked!
It's actually pretty easy to implement in C++.
void CImageDisplay::DisplayImage(LPDISPATCH image)
//m_image is a private member of CImageDisplay and is initialized to NULL in OnInitDialog
if(m_image==NULL)//initialize m_image to NULL in constructor or OnInitDialog...
m_image=image;
m_cViewer.Attach(m_image);//attach is a member of CCWIMAQViewer
else
m_image=image;
m_cViewer.Refresh();//Refresh is a member of CCWIMAQViewer
(3,780 Views)
