Measurement Studio for VC++
what causes the NI-DAQ memPageLockError (code -10447) ?
Howdy,
before i go into the question, i would like specify that i am using NI-DAQ and VC++ and not measurement studio. i didn't find any other forum specifically related to that and figured that the members of this forum would be best suited to handle this question. i would really appreciate it if anybody can help me out with this.
i am using NI-DAQ to perform double buffered data acquisition. i tried creating the buffer dynamically by using new, GlobalAlloc (Win API) and MapViewOfFile (WinAPI) inside a class. i created a worker thread that takes a pointer to an object of this class as an argument. the worker thread calls SCAN_Start and passes the pointer to the buffer as one of the arguments. SCAN_Start fails to execute and puts out memPageLockError.
i was wondering what causes this error to occur? when i don't use threading and classes but just use dynamic allocation everything works fine.
thanks for reading.
vik
(3,757 Views)
Hello Vik,
Thank you for contacting National Instruments.
Are you using Traditional NI-DAQ or DAQmx? The reason I ask is that Traditional NI-DAQ does not support multithreading and might cause that error.
Sean C.
(3,746 Views)
i am using traditional DAQ. i guess that must be causing the trouble.
i use a PCI 6052E multifunction board. can i use NI-DAQmx with that? are there any restrictions? is there a loss of functionality when using NI-DAQmx?
thanks for your help,
vik
(3,743 Views)
Hi Vik,
The PCI-6052E is supported in NI-DAQmx. There should be no restrictions or drawbacks to making this switch (DAQmx is our next generation driver). Please keep in mind that with a new DAQ driver come a new set of DAQmx C functions. You can find information about these functions by going to Start >> All Programs >> National Instruments >> NI-DAQ >> NI-DAQmx C Reference Help.
Let me know if you have any further questions.
Sean C.
(3,725 Views)
Sean,
thank you for helping me.
i will install the new set of drivers.
thanks again,
vik
(3,712 Views)
