Measurement Studio for VC++
why ChartXvsY delete previously plotted data
I'm using two CNiReal64Vector of five elements and I've set the ChartLength graph property to 5000; in my timer I fill the two vectors and I draw the points using ChartXvsY on the plot object: I see always five points on the graph because the old points are deleted (the help says that ChartXvsY doesn't delete old plotted points).
Note that if I use ChartXY (passing a matrix or single points), the old points are kept.
(3,415 Views)
Hello poldo,
You may have encountered a bug in Measurement Studio. Are you using version 6.0? If so, please download and install Measurement Studio Version 6.0 Updater. Hopefully this will solve the problem you've encountered.
David Mc.
NI Applications Engineer
(3,415 Views)
Thanks for the answer.
I'm using version 6.0 and the problem is solved installing the Updater.
(3,415 Views)
