Motion Control and Motor Drives
12VDC for Limit and Home Signals for PCI 7334 using UMI-7764
Can 12VDC be used for Limit and Home Signals for PCI 7334 using UMI-7764.
Can the UMI 7764 be damaged if over voltage is supplied to it. If so can it be repaired or it has to replaced.
(3,310 Views)
Specifications for the Limit Switchs (home, forward, reverse, etc) is determined by the specifications of your NI motion controller PCI board. The UMI functions only as a pass through and breakout for the board .
The valid limit swich voltage for the PCI-7334 is 0 - 5 V. You will have to divide down a 12 V input before running it to the UMI and to your board. The 3.3k pull up resistor is only used to pull floating voltages to TTL levels and does not protect for high voltage signals.
Please note that the UMI-7774 provides optical isolation for limit switches and extended input levels (e. g. limit switch voltages: On = 3.5 to 30 V, Off = 0 to 2 V).
Jochen Klier
National Instruments Germany
(3,301 Views)
