7334 is not recognized by MAX
Just installed a 7334 into an Windows XP Embedded system.  I first installed the software and drivers.  Shut down.  Installed the card.  Rebooted.  Started MAX.  It finds no devices.  I looked in XPe device manager and there is an unknown PCI device with and exclamation mark.  No NI devices listed.
Any Thoughts?
Chris
(3,397 Views)
Chris,
as you probably know XPe is not an officially supported OS for NI-Motion. So the issue might be related to some missing files or features in your XPe image.
On the other hand I have seen other devices like multifunction DAQ boards working just fine on an XPe system but this is not a general statement, as there is no single XPe but lot's of different target specific XPe images with specific behavior. In  fact that's the reason why it's hard for hardware vendors to support this platform.
Have you tested the board in a standard XP installation? Have you tried to use another PCI-slot on your XPe system? You also should make sure that you have installed the latest NI-Motion driver.
Sorry that I can't be of greater help in this case but maybe someone else in the forums has gathered experience with NI-Motion and XPe
Jochen Klier
National Instruments Germany
(3,385 Views)
