AKD servo drive tuning through labview
Hello All,
             I have been trying to get a AKD servo motor running through NI soft motion. I was able to configure the motor through kollmorgen workbench and after creating a labview project with required AXIS for the motor, I am not able to tune the motor. As soon as I am trying to open the gain parameters in Gain tuning panel, the system shows a Microsoft C++ library run time error and labview completely shuts down. Finally I am forced to recover the project.
Please help me sort this issue..
Thanks in Advance..:)
(5,911 Views)
i hope the problem got resolved..:D
(5,873 Views)
Hello Aks,
I have come across this problem before. If you (and anyone else on the forums) are still seeing this error, then please go to the following forum.
[1] NI Forum - MS Visual C++ RunTime Library Error
http://forums.ni.com/t5/Real-Time-Measurement-and/MS-Visual-C-Runtime-Library-Runtime-Error/m-p/2341...
Then please read PaulRB's responses. He is our Motion PSE and he will send you a fix in a private message after you send him the necessary details to him.
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
(5,812 Views)
