BSC203 motor is not appearing in APT config
Hello everyone,
I am quite new with Labview and APT so I would really appreciate your help. I installed Labview 16 (64-bit) on my 64 OS laptop. I have a new set up in my lab with a BSC203 controller and I am trying to connect everything together. After installing APT software from disk provided by Thorlabs, I wasn't able to find and insert MG17 Motor as an ActiveX in my Labview code. Therefore, I uninstalled the disk version of APT and downloaded the 64-bit version provided by Thorlabs site. That worked perfectly for the Labview, since I could find the MG17. However, APT User and APT Config still are not working. When I am trying to create a simulating configuration in APT I am not able to find as an option the 3Ch Stepper Driver BSC203 as a control unit. Can someone please help me figure out the problem?
Thank you very much for your time.
Kindest regards,
Eleni F
(3,234 Views)
Hello Elleni,
My name is Ashley Nunn. I am an Applications Engineer at National Instruments.
Thanks for your post!
Unfortunately, I am limited in how much I can help because I'm not familiar with the 3rd party software.
I have taken a look and found some documents I hope will be useful:
https://www.thorlabs.com/drawings/90b63661c30239c4-DDFFA64A-D4C9-9B8B-CA7E8BE7CB2852E7/BSC202-Manual...
https://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf
https://www.thorlabs.com/NewGroupPage9_PF.cfm?ObjectGroup_ID=1704
I would recommend contacting Thorlabs to see what insight they can provide.
Some general advice would be to check compatibility and any driver or software versions.
Kind regards,
Ashley Nunn
Ashley Nunn | MEng (Hons) | CLA | CTD
Senior Technical Support Engineer, NI
(3,198 Views)
Hello Ashley,
Thank you very much for your time and response. Unfortunately, I have already read thoroughly these documents but I couldn't find something relevant to that problem. I also contacted Thorlabs technical support but they don't respond.
Thank you again for your time.
Kindest regards,
Eleni Farmaki
(3,196 Views)
Hello Eleni,
The only thing I can think of trying is downloading the 32-bit version of LabVIEW and the 32-bit versions of the apt software.
I found a few old forum posts that could be useful:
https://forums.ni.com/t5/Machine-Vision/APT-MGMotor-Where-can-I-find-it/td-p/2662257
https://forums.ni.com/t5/Machine-Vision/Use-of-APT-objects-in-64-bit-LabVIEW/td-p/1912277
Do you have a specific need for any 64-bit versions of the software?
Ashley
(3,170 Views)
