Can I use onboard variables for load program delay?
I try to use the onboard function "load program delay" together with onboard variables. The program works and I could confirm with "read variable.flx" that the value has changed.
Versions: lv6x, flexmotion 5x
(3,748 Views)
I am not sure I understand what the problem is. An onboard probgram using variables should work without any issues if you set a delay within it using the load program delay function.
(3,748 Views)
