Looking for a controller/driver for the Haydon S&I 43000 series stepper motors.
There are some Haydon steppers listed as compatable on the motor adviser page, but I don't see the 43000 series.
(4,140 Views)
If we are not showing the 43000 series it is probably that it was an older model series and thus we might have not tried it before. I looked in the Haydon website and could never find the 43000 series, only the 46000 and the specs for those seem to be controllable using our boards. If you have the specs for the stepper motor you want to control we might be able to tell you if it is possible to do it.
(4,140 Views)
Here is a pdf of the specs I have.
(4,140 Views)
Ok, from looking at the specs on the PDF I would feel very confident saying that your motor should work peroperly with our equipment. I would reccomend using a 7334 or 7344 motion controller and an MID 7602 if you will be using up to two axes or an MID 7604 if you will be using up to four axes of motion.
(4,140 Views)
