Motion Control and Motor Drives
Can i use open loop motion stepper board to read velocity in RPM ?
(5,585 Views)
Hi Alan,
Yes you can, you will be reading back the velocity that is being generated by the motion controller.
Ken Sun
Applications Enginner
(5,584 Views)
can u fully explain the answer? i don't know how to read the velocity in RPM in open loop 7314.
(5,584 Views)
You can just call read_RPM to get the instantaneous RPM of a given axis. You must first load Steps per Rev (store_steps_rev) or Load Steps and Lines/Rev (load_steps_line) before using this function.
(5,585 Views)
