Vu,
Thanks for the response. I am using the latest NI-Motion, 7.5, with MAX 4.2, which all came in the dowload together. I'm also unning Windows XP with all the latest updates and service packs. Below is a timeline of the things I've tried, and where I am at today.
After I installed the latest NI-Motion 7.5 package, I powered down the system and installed the card. Windows recognized the new device upon start-up and prompted me to install the drivers. Windows finished installing the drivers and said the new device was ready to use.
I then opened MAX to see what it found. MAX recognized the card as being present, but reported that the card had been removed or was not responding. I tried reseting the card from the status tab, but that did not help. It continued to fail the resources test. I tried initializing the device, but it said that the firmware was out of date. I went to the firmware tab and attempted to update the firmware, but it couldn't because the device was not responding.
Various errors kept popping up during this process, "Device must be activated first", "Firmware out of date", "Read Data Buffer not empty", "Device not responding", etc. This card worked in this sytem prior to replacing the hard drive and reinstalling Windows XP (updates and service packs), so I didn't think it was a system issue. However, just to be safe, I tried different PCI slots, fail-safing the BIOS, optimizing the BIOS. Nothing helped. I tried emoving the device from MAX as well as the System, reinstalling NI-Motion, etc. Nothing helped.
I then downloaded NI-Motion 7.5 to another system and plugged the card into that system. Everything worked fine. I was able to update the Firmware, pass the resources test, reset the device, verify the serial number, etc. At least I knew the card was good.
I then took the card back to the original system and plugged it in. Windows recognized a new device and prompted me for the drivers again. Everything went fine. I then searched for the device in MAX and there it was. It was working!!! It passed the resources test and everything!!! However, MAX was now showing two cards being installed. Board 1 was not installed or not responding (which I forgot to remove from MAX when I removed the card from the system), and the card was now showing up as Board 2.
I removed Board 1 from MAX and renumbered Board 2 as Board 1. MAX prompted me to reboot the system which I did. However, when it came back up, MAX was reporting that Board 1 was not responding. The serial number was reading correctly, so I know that there are some communictions working, but the device would not reset, failed the resources test, would not initialize, nothing. Changing the Board ID and rebooting had broken the communications again.
I took the card out and took it back to the other system where I had successfully updated the firmware. The card was fine. No problems. I then removed the board from MAX in the problem system, removed the driver from the OS, powered down and reinstalled the card.
Windows detected the card and prompted me to install the drivers again, everything went OK. However, MAX is still showing the card as not installed or not responding. I'm back to square 2 (square 1 showed the wrong serial number).
I'm wondering if there are some PCI settings that are different between the two systems. Any recommendations?
Any idea why changing the Board ID would cause the device to stop responding? The card is responding to MAX serial number queries, but not to a reset command. In fact, sometimes when I first open MAX after an install, the device icon is green for a second or two, before the exclamation point appears indicating a problem. I'm wondering if MAX is failing to read data from the Read Data Buffer, which is causing the card not to respond to further queries. The status lights indicate the RDB is full and waiting to be read.
Sorry for such a long posting, but I'm hoping there is a clue in there somewhere.
Thanks for the help,
Jerome
