Can't connect Robotics Starter Kits 2.0
I already went through the NI Robotics Hardware Setup and followed it step by step, but still I cant connect the robotics starter kit2.0  to my PC. It said ''No Targets Detected''. I already tried all the possible solution on the troubleshoot page, but all of them didnt work. the power light is not on after connecting power cable. and the ethernet cable light is not on ethier after connecting ethernet cable from board to my PC. Any help on this? Thanks
(4,439 Views)
Hello Shang,
I read your forum post and I will like to know if you had this kit:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/208010
If you do I will to know if you already have all the proper drivers and modules installed. In the main page of the starter kit you can find the resources tab:
However in order to do the installation I will recommend you to have the Real Time Module and the FPGA Module too.
Warm Regards,
Randy @Rscd27@
(4,412 Views)
Thank you very much for your reply.
I have resolved my problem.
(4,373 Views)
Thanks for letting us know shang!
Randy @Rscd27@
(4,352 Views)
