how to configure epos2 24/2
I am trying to configure a maxon epos2 24/2 driver which is connected to an ec motor, to run in velocity mode. I have tried to run the example vi given in the instrument driver. The drivers have been installed correctly and I am able to see the VIs in the panel.
when i am trying to open the example vi for velocity mode, an error is coming up as <usr.lib>:\EposCmd\EposCmd.dll is loaded from C:\Program files\National Instruments\LabVIEW 2012\instr.lib\Epos\EposCmd.dll  and the affected caller is VCS_wait for target reached. AFter ignoring this error, when i run the code, a time out error is coming which i am not able to rectify. Can anyone help me with this.
Also, it will be helpful if someone can tell me how to make the eposcmd.dll file available.
Thanks in advance.
Gauri
Message 1 of 1
(3,869 Views)
