Can you help please Ultrasonic Sensor-proportional PID servo-solenoid 2-way (4-20mA)
Can you help please I have pro progarmado to file as a simulation in the attached document. I need to September Either the PID signals the transfer function of the system is controlled by the PID. Maybe I Could With A PID help please Any programming for LabVIEW 8.5 and 4 to 20 mA. I want to make to level feedback control with Continuous feed, as is in the attachment. Working with a level sensor and a Proportional solenoid valve 4 to 20 mA Danfoss EV206B thanks Mario
(6,016 Views)
Attachments are also part of the simulation work that I require the PID and able to do with the team
Mario
(6,015 Views)
Hola Mario,
Please, explain your problem in spanish because I cannot understand your explanation in english.
Por favor, explique su problema en español porque no puedo entender su explicación en Inglés.
Saludos,
Abel
NI Brazil
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(5,872 Views)
