09-25-2006 10:05 AM
09-26-2006
02:14 AM
- last edited on
04-22-2024
08:52 AM
by
Content Cleaner
The SHC68-C68-S is meant to connect the Motion I/O connector of your 7342 to either a UMI-7772 or to an NI power drive. The PWM outputs are located on the Digital I/O connector and you should use an SH68-C68-S in combination with an unshielded or shielded connector block to access these signals.
Please refer to the user manual of the 7342 for pinouts information.
I hope that helps. For the case that you need more information about how to connect the 7342 to your power drive please provide information about the drive type.
Jochen Klier
National Instruments Germany
09-26-2006 03:51 AM
thank you Jochen Klier,
is the SHC68 C68 S match with CB-68LP?
thank you again
09-26-2006 03:56 AM
09-26-2006
04:17 AM
- last edited on
04-22-2024
08:53 AM
by
Content Cleaner
09-26-2006
04:22 AM
- last edited on
04-22-2024
08:53 AM
by
Content Cleaner
ok ok , i haven't seen you latest message,
but now i have SHC68-C68-S (P/N 186380-02), witch unshielded or shielded connector block should i take ?
thank u
09-26-2006 04:55 AM - edited 09-26-2006 04:55 AM
Message Edited by Jochen on 09-26-2006 11:56 AM
09-26-2006 05:41 AM
