Hi All
I have been looking around here for a while for an answer to this question.
For me, a closed loop control system is correcting for following errors all the time, also when the move is complete.
If the load on a system changes, there will often be a need for compensation in order to keep the position right. Then you need a closed loop control system.
I have made a system using DC motors with a 7342 controller. We are in the process og getting a new similar system, where the manufacturer chosed stepmotors in the believe that it can be used in closed loop.
Is it really true that the NI version of closed loop is only performing a what you call a "pull-in" at the end of the move in order to correct for lost steps or flexibility of the connection between motor and object/encoder?
I would call this "backlash compensation" or something like that.
Why dont you make a real closed loop option. The control voltage from your servo motor control, could be fed into a voltage-frequency converter with a matchin sign signal.
This shouldn't be too complicated to accomplish.
/b
