02-09-2006 06:43 AM
02-10-2006 06:18 PM
Mor,
Ok. I had to download the manual for your device, but I think I can help you out.
1. Do you have the 9 pin D-Sub connector that provides the Auxilary Incremental Encoder, or do you have the 15 pin D-Sub connector for the sinusoidal commutation, or do you have both? I would recommend the Auxilary Incremental Encoder if possible. I need to know which one you have in order to help you completely setup your system.
2. You need to connect pin 3 of the drive to pin 1 of the Axis 1 Control connector on the UMI.
3. You need to connect pin 4 of the drive to pin 9 of the Axis 1 Control connector on the UMI.
4. You need to connect pin 4 of the drive to pin 8 of the drive.
5. You will need to change the settings on the drive so that it know you are in Torque mode instead of velocity mode (CP.10).
6. Depending on what you are going to use for feedback (Auxilary Incremental Encoder/Sinusoidal Commutation) you will need to hook the proper D-Sub connecter to the UMI, the instructions on how to do this can be found in the 735x user manual, which can be found through the link below...
http://www.ni.com/pdf/manuals/371060a.pdf
NOTE: I recommend you use the Auxilary Incremental Encoder if possible, it is easier to use and setup. If you do not have both the Auzilary Incremental Encoder and the Sinusoidal Commutation, then you will need to purchase it for your drive. Attached is an excerpt from the manual showing what I am talking about.
I hope this helps,
Lorne Hengst
Application Engineer
02-13-2006 01:57 AM
Dear Lorne,
Thanks for your response.
I have the 9 pin D-Sub connector that provides the Auxilary Incremental Encoder.
How i connect it to the umi?
I also have the 15 pin D-Sub connector for the sinusoidal commutation.
You wrote: " 4. You need to connect pin 4 of the drive to pin 8 of the drive."
its short from pin 4 to pin 8 in the drive, its ok ? i understand you ??
and then "to connect pin 4 of the drive to pin 9 of the Axis 1 Control connector on the UMI"
Thank you for your reply.
I'll connect it and try it with MAX , NI Motion & LabView
I hope i know how to do the test in MAX to be sure that i connect everything as needed.
Moti Mor.
02-13-2006 08:04 PM
Moti,
As long as the voltage output of the 9-Pin D-Sub connector is ttl, you will want to connect the "Encoder Phase A" of the UMI to "A+" of the 9 pin connector. "Encoder Phase B" of the UMI to "B+" of the 9 pin connector. "Encoder Phase A-" of the UMI to "A-" of the 9 pin connector. "Encoder Phase B-" of the UMI to "B-" of the 9 pin connector. "Encoder Index" of the UMI to "N+" of the 9 pin connector. "Encoder Index-" to "N-". And finally "Digital Ground" to "GND".
"You wrote: " 4. You need to connect pin 4 of the drive to pin 8 of the drive."
and then "to connect pin 4 of the drive to pin 9 of the Axis 1 Control connector on the UMI""
You are right, you shouldn't short those pins. I would either connect the two pins together via a large resistance so that the differential input will be referenced to the ground of the device.
Lorne Hengst
06-11-2006 11:00 AM
06-12-2006 04:38 PM
