Contouring in 4 axes of motion
Lately I'm also getting these errors after the first:
Error # -70125 occured at LoadVectorSpacePosition on Coordinate 2
Possible reasons:
Motion: -70125 (NIMC_wrongModeError)
The function was not executed because it was attempted at an illegal time.
Error #-70063 occured at Start on Coordinate 2
Possible reasons:
Motion: -70063 (NIMC_bufferConfigurationError)
The buffer has not been configured properly.  Buffer type cannot be changed.  The buffer might exist in ROM, but has not yet been configured since the last power cycle.
Message 11 of 16
(2,497 Views)
You can disregard the most recent post with the two extra errors listed - I found the problem for those.
I'm still having my original problem, though.
Message 12 of 16
(2,494 Views)
Kate,
The error you are receiving has to do with the timing between the start and hault commands.  The error is an isoltated bug in our older driver versions (occurs less than 5% of the time) and can be ignored.  The error should be fixed in the latest version of our motion driver (NI-Motion 7.2).
If you are using the older version of the driver, please disregard the message.  If you have upgraded to NI-Motion 7.2 and still see the error, please reply and let me know so I can pass your observations along to my R&D team.
Scott Savage - National Instruments
Message 13 of 16
(2,475 Views)
I am also having a problem with fourth axis. I have labview 8, NI-motion 7.2 and PCI-7356
My code is similar to Jochen's example, but servos don't move and labview still gives the following error message:
Error # -70145 occured at Start
and
Error # -70145 occured at LoadVectorSpacePosition
-both two times.
Code works ok with one vector space only. Any ideas what could be the problem here?
Tommi
Message Edited by tommi_be on 07-11-2006 09:38 AM
Message 14 of 16
(2,347 Views)
Tommi,
Your problem might be that you only assigned one axis to the second vector space.  Try "Axis 4", "none," and "none."  (For future reference, Axis 4 must be listed first.  "none," "Axis 4," "none" won't work either.)
Kate
Message 15 of 16
(2,344 Views)
Thanks Kate! Now it works perfectly. Smiley Happy
Message 16 of 16
(2,327 Views)
