The Script is a code of CNC?
Hi, I'm using the eagle program from cadsoft to create a PCB, now I can create a code in script to create the PCB in a 3 axis machine with a motortool, everything is working ok, but the question is:
This script code is a derivation of a CNC code? and if it is, it work with any standard?
Example:
GRID mm;
SET OPTIMIZING OFF;
SET UNDO_LOG OFF;
SET WIRE_BEND 2;
LAYER 101 outmil1;
SET FILL_LAYER 101 Interleave;
CHANGE LAYER 101;
CHANGE WIDTH 0.300;
WIRE (26.5689 37.4730) (26.5300 37.4569)
(26.4103 37.4569)
(26.3258 37.3723)
(26.2194 37.3283)
(26.0269 37.1357)
(26.0269 37.4730)
(26.5689 37.4730);
(3,649 Views)
Does not look like typical CNC M or G codes. Looks more like the info to generate the drawing specific to your CAD package.
(3,635 Views)
Yes analogKid, thats the info to generate the CAD package, more specific are the final coordinates in x and y axis, but this kind of code (script) can be classified as a CNC code?
(3,618 Views)
