HI All,
I am facing a problem in Motion Controller.
We are using PCI 7344 and UMI 7774.
Now their is a connector on the Motion control card for Digital I/O.
In this Pin No 5 and Pin No9 are PWM1 and PWM2 respectively.Now I have used to VI PWm duty and config PWM. I am seeing the PWM waveform on CRO.But to my surprise the output is not matching the required data.
IF you go for HElp and click config PWM VI block , you can see a table given where the internal clock selected corresponds to a particular frequency in 734X and 735X.Now since I am using 7344 my frequency should match with 734X table , whereas this is not happening and
my frequency matches the table of 735X.
SO i am bit confused about the controller specs or is someor the other way Iam missing some thing more.
Regards
Manish Karnik
Cruiser Controls
Mumbai.
