Control a VFD via cDAQ 9178
This is more of a follow up question then a response.
When you connect the VFD analog output to input of NI9201, what is that reading?
When you connect VFD analog output to output of NI9263, is it using voltage signal to control the frequency in Hz that drive the motor?
Thank you.
Message 11 of 11
(378 Views)
