Motion Control and Motor Drives
Control different dc-motors with PCI-7358 and two MID-7654
I’m a engineering student at the technical university of Braunschweig in Germany. Within my diploma thesis I have the task to realize a motor control. I’m new in motion control an so my question is maybe quite simple.
For the motion I have 4 several types of brushed Pittman dc-servo motors (all in all 7 Motors) of the Pittman gear motor series GM8000 and GM9000 with the following technical specs:
Pittman GM8722:
Reference Voltage: 12 V
Resistance: 3,1 Ω
Inductance: 1,57 mH
No-Load Current: 0,25 A
Pittman GM8722:
Reference Voltage: 24 V
Resistance: 12,1 Ω
Inductance: 6,27 mH
No-Load Current: 0,12 A
Pittman GM8723:
Resistance: 2,17 Ω
Inductance: 1,17 mH
No-Load Current: 0,27 A
Pittman GM9433:
Resistance: 1,08 Ω
Inductance: 0,84 mH
No-Load Current: 0,3 A
My Question is now, is it possible to control these motors with the NI motion controller unit NI PCI-7358 in conjunction with two servo motor power drives NI MID-7654?
Thanks for any help that you can provide!
_______________________________
Christoph Boese
Technical University of Braunschweig
Institute for Microtechnology (IMT)
(4,822 Views)
Hello Christoph,
if you look inside the datasheet of your GM8xx2 or GM8xx3, you can see the Peak Currents mentioned
by the manufacturer. The MID-7654 delivers 5 A per Axis so u can just compare if it´s sufficient or not.
Hope this helps you
regards
Marco Brauner NIG
(4,795 Views)
sorry I forgot,
Yes u can use the PCI-7358 as the controller for the DC-Motors
Marco
(4,798 Views)
Ok thank you! That’s with the controller sounds really good but I still have the problem with the power drive for the dc-motors.
In the datasheet I found the peak current for each motor. They are all between 1,99A for the 24 V GM8722 and 11,1A for the GM9433. The peak output current of the MID-7654 is in comparison with the datasheet 10A per axis.
Is it correct? And does it work with my motor, if I don’t need the whole torque the GM9433 can deliver?
The second thing I’m still a little bit afraid of is the output voltage of the MID-7654.
My question is here: are the 48V too high for my 12V and 24V dc-motors?
Don’t they rotate too fast because of the higher voltage?
Can I limit the voltage of the MID-7654 or instead of the voltage the rotation speed with the PCI-7358?
Many thanks for any help!
Christoph Boese
(4,764 Views)
