05-15-2007 10:33 AM
I’m a
engineering student at the technical
For the
motion I have 4 several types of brushed Pittman dc-servo motors (all in all 7
Motors) of the Pittman gear motor series GM8000 and GM9000 with the following
technical specs:
Pittman
GM8722:
Reference
Voltage: 12 V
Resistance:
3,1 Ω
Inductance:
1,57 mH
No-Load
Current: 0,25 A
Pittman GM8722:
Reference
Voltage: 24 V
Resistance:
12,1 Ω
Inductance:
6,27 mH
No-Load
Current: 0,12 A
Pittman GM8723:
Reference
Voltage: 12 V
Resistance:
2,17 Ω
Inductance:
1,17 mH
No-Load
Current: 0,27 A
Pittman GM9433:
Reference
Voltage: 12 V
Resistance:
1,08 Ω
Inductance:
0,84 mH
No-Load
Current: 0,3 A
My Question is now, is it possible to control these motors with the NI motion controller unit NI PCI-7358 in conjunction with two servo motor power drives NI MID-7654?
Thanks for any help that you can provide!
_______________________________
Christoph Boese
Institute for Microtechnology (IMT)
05-16-2007 08:18 AM
05-16-2007 08:22 AM
05-21-2007 06:15 AM
Ok thank you! That’s with the controller sounds really good but I still have the problem with the power drive for the dc-motors.
In the
datasheet I found the peak current for each motor. They are all between 1,99A
for the 24 V GM8722 and 11,1A for the GM9433. The peak output current of the
MID-7654 is in comparison with the datasheet 10A per axis.
Is it
correct? And does it work with my motor, if I don’t need the whole torque the
GM9433 can deliver?
The second
thing I’m still a little bit afraid of is the output voltage of the MID-7654.
My question
is here: are the 48V too high for my 12V and 24V dc-motors?
Don’t they rotate
too fast because of the higher voltage?
Can I limit
the voltage of the MID-7654 or instead of the voltage the rotation speed with
the PCI-7358?
Many thanks for any help!
Christoph Boese
