Control of Siemens Simotion over XML-OPC
HI,
I am trying to control a Siemens Simotion unit over XML-OPC. With a XML-Browers we can access the data inside the Simotion. But it was not possible to open a connection with CVIXMLLoadDocument
Does anyone of you have experience with XML programming?
Does CVIXMLLoadDocument need a special format or is this defined in XML? That means does CVIXMLLoadDocument look for a special document? Or how does it work ?
Greetings
Oliver
(3,987 Views)
(3,968 Views)
