Converting counts per revolution to mm
I have a stage with an encoder resolution of 2048 cts/rev and gear ratio of 28.4:1. How do I calculate the distance traveled in millimeters?
Ifenna
(10,791 Views)
Not enough information.  What kind of stage?  Screw? Belt?  You need to know the distance your stage moves based on an input of 1 revolution.
(10,790 Views)
Hi
   We need to know the Diameter(D) of your wheel ( for rotary encoder )
1 round = 2048 ct =Pi x  D = 360 deg
example : if D= 200 mili-meters       ==>   2048 ct =3.14*200=628 mm
Then you resolution is   Resolution (mm)= (628*1)/2048 =0.307 mm   This meam : 1 count of your encoder you do 0.307 mm a travel
ANd now you multiply by the racio of you gear
(10,713 Views)
The only additional information I have is Drive screw pitch which is 0.4mm/rev. I this the distance traveled in one reveoluton?
(10,675 Views)
Do you have schematic or draw ?
(10,671 Views)
Distance(mm)=2048*28.4/0.4
(10,644 Views)
