Starting Motors
I am building a Ping Pong Ball Vending Machine. I want to program LabVIEW so that every time a purchase has been made, the motor spins for a set interval each time. I already have it programmed to recognize coins and each time a purchase has been made. What do I need to create in order for the motor to run every time a purchase has been made?
(5,485 Views)
You need to provide significantly more information.
(5,483 Views)
Sorry I'm a LabVIEW rookie. What do you need to know?
(5,480 Views)
Everything!
  • What is the hardware?
  • How is the purchase sensor interfaced to the computer? Can you show us your code?
  • How are the motors connected? What kind of motors (stepper, analog, etc.)
(5,468 Views)
Hi
    you can read this to start ,
   i think this will help you  http://www.ni.com/white-paper/12127/en/
 And after probably you will have more questions Smiley Wink
(5,408 Views)
