Creation of a pulse at configurable multiples of incomming RTSI pulses
Hello!
I'm using a 6024E multifunction DAQ device. Over the RTSI bus I'm triggering the counter of this card (approximately with 50 kHz). I'm using the attached example.
Is there a way to generate a pulse at configurable multiples of the incoming RTSI pulses (Right now I’m getting an output pulse for every RTSI pulse)?
Thanks in advance for your help.
Martin
(3,187 Views)
Hello Martin,
as far as I know is there no way to generate faster pulses than the RTSI line delivers. With a second timer you can devide the speed down but not up.
Kai Kratt
(3,167 Views)
Addition:
You mustn't use the counter, it can be any PFI line. You can use a "pulse train generation" example to adjust the proportion between on and on state.
Kai Kratt
(3,162 Views)
