How can I configure different voltage ranges for individual Analog input channels of PXI 7352?
Sir,
I am using the first two analog inputs of the motion control card PXI 7352 for my application. One is connected as a potentiometer feedback to Axis 1 and it is in the range +5V to -5V. I am using another analog channel to read the voltage from a load cell with the range of 0 to 10V.
In MAX, I can't able to configure two different ranges for individual channel of the motion card. Is there is any procedure to do that? Kindly clarify me.
Ramkumar. D
Soliton Technologies,
India.
(3,720 Views)
Hello Ramkumar,
For the PCI 7352, there is only one amplifier that is used for all of the board's analog inputs. This means that there is only one range that can be specified and it will be applied to each analog input channel.
If you want to have multiple ranges, you may be able to perform some signal conditioning before the signal reaches the board and then manipulate the data in LabVIEW or another programming environment to scale it to reflect the actual readings that were acquired.
Scott R.
Scott Romine
Course Development Engineer
(3,715 Views)
Dear Scott,
Thanks for your timely help. I will try it out.
Ramkumar. D
(3,705 Views)
An arrangement of operational amplifiers (instrumentation amplifier or true differential amplifier) can solve this problem. You can 'shift' the output voltage of such a circuit by feeding the input signal to one of the inputs and a suitable voltage to the other one. I think any technician with some experience in analogue design should be able to build such a circuit. You will also need an additional power supply with two voltage outputs in the range of +/-12 to +/-18V.
(3,700 Views)
