Motion Control and Motor Drives
ESP300 error
I found an old ESP300 controller that I am trying to get to work. The controller does not reply to any RS232 commands. I checked with a similar ESP300 that is known to work and same computer: no problems communicating.
After power on, it takes quite a long time to turn on the lights, and when it does, axis 1 is led is yellow and axis 2 and 3 are red. The controller does not have advanced front panel i.e.. It only has three leds for axis 1 to 3, keypad connector and a stop button.
I took a look inside and while starting up, leds D1 to D3 are off and D4 is on. After the lights appear in the front panel, D1 to D4 are all on.
I disconnected all driver modules and now D1 to D4 turn on almost immediately after powering on. However, after a while, the front panel lights up in a similar way i.e. axis 1 is led is yellow and axis 2 and 3 are red.
What does the yellow-red-red error mean? Can it be fixed somehow?
There are some jumpers inside, what is their function? Since I was not the original user of this box, I'd like to know what setting they should be in.
Thanks for all the help!
(5,359 Views)
It appears that you are using a Newport controller.  I would recommend posting on their forums.
Applications Engineer
(5,339 Views)
