Encoder circuit for dc-motor
Now i have make all the necessary installation, and all the hardwares are working properly, and i move the dc-motor, by using MAX and LABVIEW, but know i have a problem, which is the encoder, which gives feedback to the controller(PCI-7340), i have made a circuit of the mouse, but when i try to install it in theUMI-7774, the UMI power is off, since ithink there is asort circuit, so now i want a circuit that i want strongly and urgently an quadrature encoder circuit which is compatible withUMI-7774, and which i can make, so if any body have an idea about this quadrature encoder circuit, i hope that he can reply me.
And thank you
(5,276 Views)
Do you really want to build a quadrature encoder by your own? You can find extremely cheap quadrature encoders as COTS products. Here is an example. If you spend more than one hour of your work time to build such a device by your own it will be much more expensive than this one...
Jochen Klier
National Instruments Germany
(5,253 Views)
