Hello!
I still have my problem, but it might be slightly different from what I described above (although the result is the same for me), so here is a description of what I do :
1) I get the current position
2) I set the target to this position minus 3 rotations (the motor should be mecanically blocked after only one rotation)
3) I check if the move is complete
4) I check if there was a following error (the following error parameter is set to less than 5% of one rotation)
The change between my previous tests and the latest ones is that I know there is no more "unwanted" mechanical block. Bus still sometimes, the motor turns only a few steps (or not at all sometimes), and stops (but the axis is not killed) without any followwing error, as if the destination was reached properly.
I also tried to change the board (we have two running), but I still have the same problem with the other one.
Any clue, someone?
Thanks for your help
Christophe
