Generate DC voltage to control an electric motor
Hello. I'd like some help to generate DC voltage to control an electric motor using a NI PXI-6221 M Series Multifunction DAQ and an SCB-68 Connector Block. I'm plugging one wire of the motor to "AO GND" and another to "AO 0". In LabVIEW 2017, using DAQ Assistant, I go to Generate Signals > Analog Output > Voltage > Channel ao0 > Generation Mode: Continuous Samples. Using Simulate Signal VI, I generate a DC Signal, offset 5 (let's say I want +5 V). Both are inside a while loop. That doesn't work. But when I plug one wire to "AO GND" and another to the constant "+5 V" pin of the connector block, it works. I think there's a problem with the generation of the signal in "AO 0". Could someone help me?
(3,354 Views)
Accepted by topic author igorgrz144
Yes, it is because the output current of AO is limited (often under 10mA). You need a motor driver to handle the large currents required by the motor and you cannot control directly from just an AO (yes, it might seem possible but only in theory).
Santhosh
Soliton Technologies
(3,344 Views)
It makes sense. Thank you for helping. You mean I need an amplifier to generate the current required, right? Should the PXI/PCI-73xx motion controllers do the job? It's a 12V brushed DC Motor.
(3,331 Views)
Motion controllers are the brains of the motion control system, they work with motor drivers to control motors.
Santhosh
(3,320 Views)
