How do I control Newport's CONEX-CC using LabVIEW?
Hi, I'm a college student who wants to operate the CONEX-CC device of Newport. I want to use LabVIEW to operate CONEX-CC, but I just started studying LabVIEW, and I want to get help because there are so many difficulties for me.
https://www.newport.com/p/CONEX-TRA12CC
First of all, if you look at the page, you can see the CONEX-CC device, and you can download the manual and software. There is also a GUI program created by Newport, but I want to make three CONEX-CCs run as one software based on the (x, y, z) axis. Therefore, I have three CONEX-CCs now, and as my first goal, I am going to operate the source code provided by Newport and analyze the code. But I haven't tried anything because the source code hasn't been executed properly. I want you to tell me the primary way to solve this problem.
Among the attached files, the zip file contains the source code, and I think you can refer to the pictures. Thank you so much for reading the long comment! I'd be even more grateful if you could help me!
(2,783 Views)
Hey! I'm kinda in the same spot you are. Have you had any luck?
(2,709 Views)
