Help needed with this program
I would like to enquire on whether this VI  has any error. I need to configure the digital input as a positive limit switch which is a sensor which when blocked, will produce a change in the voltage pulse.
(3,314 Views)
I could not open. Can you save it for LabView 8.2 or 8.5?
Andy
Best Regards,
Andy
_____________________
PCI-7356@UMI7764; PCIe-6320@SCB-68; LV2011; Motion Assistant 2.7; NI Motion 8.3; DAQmx 9.4; Win7
(3,311 Views)
