Help wiring a Delta Tau UMAC to interface with labview.What is needed?
Here is an example for communicating with a PMAC.  You don't have to open and close with each command.  Actually, I usually just use the open once at the beginning of a program, then don't use the close.  You can either query the PMAC or just send commands using this VI.
Message 11 of 25
(4,394 Views)
Thanks for all your help,
I'll keep you posted.
Message 12 of 25
(4,389 Views)
Thank you for Brain Beal's material
Message 13 of 25
(4,170 Views)
Hi, Brain Beal. Thanks a lot for your material attached. But unfortunatelly, My Labview version is 8.2.1, so I can't open your VIs in folder PMAC example written by Labview 8.5. Could you please kindly save it as earlier version VIs? Thank you!
My mail box is xu.wang@delphi.com
Message 14 of 25
(4,168 Views)
Here they are in 8.2.
Message 15 of 25
(4,162 Views)
Thanks a million, Brain! You are a great person! May I have your mailbox?
Message 16 of 25
(4,145 Views)
HI there Brian Beal,it's me cysyfforever
Thanks you so much for your reply,you truly are a great person
here is my problem:
I've ran into the trouble of how to control and communicate with the PMAC and UMAC recently,(type:Turbo PMAC2 clipper card and UMAC CPU Control),I‘ve downloaded the examples you've posted before,but it turn out that the drivers and the ActiveX files of the PMAC has already changed that I cannot run you VI even after I setup the PMAC softwares,I tried to creat VIs the way you did but I just cannot find the Pecommserve,I guess it has changed to the Pmacserve so I used the Pmacserve instead but errors just come up,I was so confused and I cannot find any other example neither,could you help out,I would be very very appreciate your help,Thanks a million!
Message 17 of 25
(3,187 Views)
PS:the motion that I want to do with the PMAC is:linear motion and Sinusoidal movement,would that be hard?
Message 18 of 25
(3,184 Views)
I just set up a new Clipper this week with Labview using the same VI's.  What Delta Tau software package did you install?  I noticed that there is an error in the PcomGetRespEx.vi that I posted.  It has a spare VI in the block diagram.  Delete the Pcom Open Close VI.  You need to be sure to set up the PMAC with the Delta Tau software.  Can you communicate using Pewin32Pro2?
Message 19 of 25
(3,173 Views)
It depends on how well you understand the PMAC.  You must have a good understanding of the PMAC before you can control it from Labview.
Message 20 of 25
(3,171 Views)
