How can I make MG17Piezo ActiveX automated without using jog to move the Nanomax stage
If you use while loop, you do not control the loop with iterations, but you do with stop condition. use graterthan command, as position reaches to max goven in input, while loop stops.
Message 31 of 39
(3,931 Views)
So I can delete this from the code and I should remove the iteration from the while loop? Can you send me a picture of how it should be done?
Tania
Message 32 of 39
(3,930 Views)
I've attached the proposed changes. What do I put in place of the stepsize multiplied by iteration inside the loop?
Tania
Message 33 of 39
(3,928 Views)
Does the picture I sent seem alright? Are those the only sections I need to delete?
Many thanks,
Tania
Message 34 of 39
(3,924 Views)
1. you can delete top left part of the loop, as it does nothing for while loop.
2.  second one, i think you do not need to delete this one as it will update your position in the loop as it runs. Only you have to modify (add increment one to 'i' so that initial position is equal to step size.
3. If you can use DAQ functions instead of DAQ assistant, it will be more accurate and convenienet. for this, forst write code for DAQ and inport this as subVI into the main program .
if you want more details, skype me to mahendarkumbham or email me to mahendarkumbham@gmail.com 🙂
mahendar
Message 35 of 39
(3,921 Views)
So regarding point 2 I just leave the iteration bit as it is. How do I add the add increment one to i bit to the code? Isn't it doing that by itself?
Tania
Message 36 of 39
(3,918 Views)
Hi Mahendar,
Hope you're well!
I am currently using the setvolt code that you showed me for the open loop. If I am to carry out a 2-D scan in both x and y, how can I add that to the code?
Kind Regards,
Tania
Message 37 of 39
(3,870 Views)
Hi Tania,
Did you know how to control the stage to scan a 2-D image ? I have the same problem . If you had figured out it , could you share your labview code with me?
Thank you very much!
Kind Regards,
Zhangxin
Message 38 of 39
(3,810 Views)
Hi Zhangxin,
I just saw your post and I haven't figured it out till now. Have you figured it out by any chance?
Kind Regards,
Tania
Message 39 of 39
(3,774 Views)
