Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can i READ Steps / Revolution
stefan_hartmann
Member
03-17-2008
11:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I'd like to READ the predefined (in MAX) "Steps per Revolution" (depending on the Board ID and Axes). Is this not possible?
I am using LabView 8.5 with NI-Motion-VIs, where just a LOAD "Steps per Revolution" is available.
Go to Solution.
0
Kudos
Message
1
of 2
(3,423 Views)
Reply
Accepted by topic author
stefan_hartmann
Re: How can i READ Steps / Revolution
Jochen
NI Employee (retired)
03-18-2008
02:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The NI-Motion API doesn't provide an option to read this value. If you want to have complete control about your motion settings in your application, you should consider loading them in your application.
Kind regards,
Jochen Klier
Kudo
Message
2
of 2
(3,417 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
