How do I read the output of a shaft encoder to control the angle of a motor on myRio
Hello guys,
I am new to control and I have a project to control the position (angle) of a DC motor using a shaft encoder.(600 pulses)
I  am using myRio and labview and was able to get a digital output from my encoder.
I need to design a PID controller to control my motor so most probably PWM is used for velocity.
What to do with theses readings, how to transform into angle position?
and how can i use the PID option on myRio.
Any help is appreciated and thank you for your time
(5,105 Views)
I have the same problem. Have you found a solution?!
(4,589 Views)
