Motion Control and Motor Drives
How do I use Softmotion & SolidWorks to develop a project that involves moving a 3-wheeled based robot?
I already have a labview code that is able to generate signals for 2 different motors (step and direction). Usually when you use stepper motors you need these 2 parameters which are basically the only ones you need to make the motors move. By using these 2 signals I want to move the robot I assembled in SolidWorks. I'll attach a image of the assambly if it works.
Thanks in advance
Juan
(5,383 Views)
Hi bmjunar,
Here are some general links that might be helpful as you try to use Softmotion and SolidWorks:
http://zone.ni.com/devzone/cda/tut/p/id/9566
http://www.ni.com/virtualprototyping/training.htm
Best Regards,
Michael B.
Applications Engineer
(5,349 Views)
