How do you control the motor in the continuous mode ?
I use the NI 7334, I would like to create the program to control the motor in the continuous mode. please help me.
Thank you very mich.
(3,165 Views)
Hellow water2006,
Thank you for using our discussion forums.  In regards to continuous mode, are you referring to a constant velocity motion?  There are several examples on our website which will give you a good start on setting this up.  In particular the "Constant Velocity Move" example which is found at http://zone.ni.com/devzone/cda/epd/p/id/1206
I hope this helps.
Vu D
(3,134 Views)
