How do you control the slide with keyboard ?
I would like to control the slide with keyboard the following picture with the increment and decrement function.
Thank you.
(4,153 Views)
Hi water2006,
A way to do this would be to use an event structure to detect when the arrow keys are pressed.  I have attached links to two different example programs.  The first shows how to detect key downs with an event structure and the second uses this concept to jog the axis of a motor depending on mouse click.  You can hopefully use these two examples to create what you are wanting to design for your system.  Good luck.
Using the LabVIEW Key Down Event  http://zone.ni.com/devzone/cda/epd/p/id/3924
Forward Reverse Interactive Jog http://zone.ni.com/devzone/cda/epd/p/id/2952
Vu D
(4,108 Views)
Dear Vu D,
I cannot download them because I use the LAN network, please help me to ZIP them and send to my email td2006@sanook.com
Thank you very much for your help.
(4,104 Views)
Dear Vu D,
When I copy the code (keydown.vi) that it use the event for capture the key to my main program, the keydown program works but my main program no work, please suggest me about this problem.
Thank you very much
(4,088 Views)
Hello water2006
If you are able to get the keydown program to work, the next step would be to incorporate it into your VI.  The basic concept of this example is to show how various events trigger depending on the key stroke.  You can use this basic concept to create a similar event structure for your main program to trigger motion depending on which arrow key (Vkey) is pressed (that is, include the motion actions you are trying to run within the event triggered).  I hope this helps.
Vu D
(4,070 Views)
Thank you,
(4,066 Views)
