03-25-2009 10:42 AM
03-26-2009 01:04 PM
Hi rwelch,
How are you doing modulo breakpoint on the 7330? The modulo breakpoint is only supported on the 7340 controller card. Thanks.
03-26-2009 03:58 PM
Thanks for getting back to me. The help for the Load Breakpoint Modulus indicates the 7330 is compatible. (if you select the Device Compatibility link) Is there any definitive document that discusses programming the 7330? I was unable to find such a document.
Thanks again,
rwelch
03-27-2009 10:14 AM
Hi rwelch,
Apologies for my mistake. According to one of the training manuals that I had here, the modulo breakpoint feature was only in the 7340 series, but I have found other information here that indicates otherwise. Now let's solve your issue.
It sounds from your original problem statement that your issue begins with not seeing the breakpoint trigger on the motion card. Have you worked with your motion card in MAX? In 1-D Interactive Mode, you can set most of the same settings that you have in LabVIEW, and you can monitor the breakpoint trigger in the Advanced tab. You might want to confirm that you are not getting a breakpoint trigger here. If you are, then your LabVIEW code is the issue. If not, we may have deeper problems.
