Motion Control and Motor Drives
How doing cycle mode
I have just read your last posting again and I have found that in fact you are running in closed loop stepper mode (looks like I was a bit too much in a hurry when I wrote my last post).
So this seems to confirm my assumption. I'm pretty sure that the reason for your problem is the one that I have describe in my last post. To confirm this please configure your axis as open loop stepper and run a test. I'm almost 100% sure that with this configuration  you won't see the problem anymore.
Please make sure that you have set the right parameters for steps/rev (motor) and counts/rev (encoder). If your encoder specifies lines/rev you will have to multiply this value by 4 to get the counts/rev. For the correct steps/rev value you will need to multiply the physical motor steps/rev value with the microstepping factor of your drive (e. g. a motor with 200 full steps/rev and a drive with 10x microstepping will result in 2000 steps/rev effective resolution). If there is a gear between the encoder and your motor you will also have to take care of the gearing factor.
Jochen
Message 11 of 11
(815 Views)
