06-28-2019 01:13 AM
HI,
I have NI-7344 motion control card. I have limit the DAC output to +-5V from MAX software. Now the issue is how to calibrate the counts to voltage? I don't find any setting for lets say 1000 counts is +5v and -5V in opposite direction. The 500 counts should be 2.5V.
Kindly help or suggest examples for this.
07-01-2019 05:34 PM
Hi AB.C
Please check this link
07-01-2019 11:18 PM
Thanks for your reply. I am asking "How can I use NI MAX to calibrate this output. Because I am using Ni motion assistant and the value saturates at +-5V but does not translate to my complete range".
07-02-2019 08:35 AM
Why don't you just use the count number as an input to calculate the voltage and write that on the output?
07-03-2019 02:08 AM
I have limited output to +-5V from NI MAX. For different range of inputs it keeps on giving 5V as out. Which means it is saturated on 5V. While I want to calibrate my output to +-5V that is from my range of inputs should b availabe with 5V.
07-04-2019 03:11 PM
Why don't you do this programmatically from LabVIEW?
07-04-2019 11:41 PM
I am new to labview, still learning. So I thought Motion Assistant and NI MAX will be easier to first test the outputs/hardware and then move to labview. Can you suggest good examples or tutorials for learning motion controller programming in labview?
09:11 AM
- last edited on
08-28-2025
03:49 PM
by
Content Cleaner
Tutorials:
https://www.ni.com/en-us/innovations/white-papers/06/fundamentals-of-motion-control.html
https://www.ni.com/en-us/innovations/white-papers/12/building-an-ni-motion-control-system.html
https://download.ni.com/support/motion/Manuals/tutorial.pdf
https://www.ni.com/docs/en-US/bundle/323329a/resource/323329a.pdf
There are examples in the NI Example Finder. You can find them as the attached picture.
07-08-2019 11:28 PM
Thank you. I am grateful.
07-10-2019 03:11 PM
You are welcome
Good luck with all!
