How to control Aalborg Stepping motor valve?
I want to control a stepping motor valve from Aalborg.
The operation manual is here:
http://www.aalborg.com/images/file_to_download/A_SMV%20Manual%20TD0305M%20RevC.pdf
It seems that beside having TTL output, I also need to have:
1) 0 - 2.5 VDC analog output for speed control
2) 12VDC CMOS logic output on pin 8 for direction control.
I would like to know if there is a NI module which can output 12 VDC CMOS logic signal.
(4,196 Views)
(4,178 Views)
