12-17-2008 07:28 PM
Solved! Go to Solution.
12-18-2008 02:25 AM - edited 12-18-2008 02:26 AM
To accomplish what you want you just need to load the parameters for both axes independantly and start them with Start Motion.flx. Assuming that you are using LabVIEW, here is a screenshot from the Start Motion.flx front panel, that shows, how to start both axes simultaneously with a single start command.
I hope that helps,
Jochen Klier
12-18-2008 10:58 AM
Jochen,
Right you are, that did the trick! Many Thanks!
David
