How to move on two axis, each axis having a different velocity, using a PXI-7332
Using a PXI-7332, I need to do two simultaneous moves, one on axis 1, one on axis 2, with independent velocities (and targets) for each axis, input in steps.  Can some one please point me in the right direction.  I have been unable to find an appropriate example.  Thanks in advance.
(3,836 Views)
To accomplish what you want you just need to load the parameters for both axes independantly and start them with Start Motion.flx. Assuming that you are using LabVIEW, here is a screenshot from the Start Motion.flx front panel, that shows, how to start both axes simultaneously with a single start command.
I hope that helps,
Jochen Klier
Message Edited by Jochen on 12-18-2008 09:26 AM
(3,830 Views)
Accepted by topic author Dave@Ventec
Jochen,
Right you are, that did the trick!  Many Thanks!
David
(3,818 Views)
