I am having a problem with the valuemotion 5.01 sub V
I Wait for Move hanging in my program. It hangs when my "save" routine is loaded into memory (file open, close, write, etc.). Executing in "step by step" mode the program will work, but the program hangs in real time at the Wait for Move sub VI. Any ideas?
(4,564 Views)
I Wait for Move hanging in my program. It hangs when my "save" routine is loaded into memory (file open, close, write, etc.). Executing in "step by step" mode the program will work, but the program hangs in real time at the Wait for Move sub VI. Any ideas?If my memory serves me correctly there is a tight while loop in this vi. It is probably consuming all the CPU time and therefore "hanging". Try putting a wait for next ms in the while loop, you can do 1 or even 0 ms and this will cause the CPU to allow other processes to run.
(4,564 Views)
