I am trying to configure a PCI card through Labview. But it is not in the default set of drivers. I came to know that you offer 'freeware' software in your website. I am not able to find it. Can you suggest me some way of getting it.
I am trying to configure a PCI card through Labview Motion control software. But the card does not appear in the default set of drivers an i am not able to configure the port using labview motion control. I came to know that you offer 'freeware' software in your website. I am not able to find it in your website. Can you suggest me some way of getting it.
(3,065 Views)
Currently, if your PCI card is not from National Instruments, you will not be able to configure it with the LabVIEW motion control tools. Usually, driver development for non-NI boards needs to be done by the manufacturer of the board because it often requires low-level knowledge of the board. The "freeware" you mentioned might be the hundreds or GPIB instrument drivers that you can download but these are for GPIB instruments. Usually, for non-NI PCI boards, you have to go to the manufacturer of the board to get the LabVIEW drivers. Hope that helps.
(3,065 Views)
